Carrier Infinity WeatherMaker Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2012, 01:08 PM   #1
Within the last two weeks my furnace keeps shutting of & in order to start it i have to turn of the emergency/kill switch -turn down the thermostat-push in the reset button on the side then turn up the thermostat & it works every time but it shuts off at least once a day--could some one tell me what the problem is or a solution?
coolwater165 is offline   Reply With Quote
Old 03-09-2012, 01:24 PM   #2
An old Tradesmen
Rewards Points: 8,176
Post a pic of the reset you are pushing. Sounds like a roll out switch. if so, your furnace may have a very serious problem.
Old 03-09-2012, 01:48 PM   #3
infinity weathermaker gas furnace
Thank you for you response but unfortunately i do not know how to post a picture of the furnace but i check on the furnace on the internet & each part of the furnace is detailed & like you said it was listed as #17 Roll Out Switch---it's on the right hand side of the Burner Assembly --there are two wires going to the side of it with a small switch (which you push in to reset)--you said it could be serious issue?
Old 03-09-2012, 02:22 PM   #4
An old Tradesmen
yes, it could be a restricted secondary heat exchanger. or cracked primary heat exchanger.
The Following User Says Thank You to beenthere For This Useful Post:
coolwater165 (03-09-2012)
Old 03-09-2012, 05:22 PM   #5
Guy must have a busted period key on his key board
hvac5646 is offline   Reply With Quote
Old 03-09-2012, 07:13 PM   #6
Well if it isn't Mr Perfect.
Old 03-10-2012, 07:43 AM   #7
N o disrespect intended, but there is a good reason to punctuate in your posts here.
It could make the difference between a misdiagnosis or a solution to you hvac problem.
The Following User Says Thank You to hvac5646 For This Useful Post:
coolwater165 (03-20-2012)
Old 03-10-2012, 08:11 AM   #8
Rewards Points: 292
You should see him after he's had his morning ration of coffee!
veesubotee is offline   Reply With Quote
Old 03-20-2012, 11:00 AM   #9
carrier furnace issue
Within the last two weeks my furnace keeps shutting of & in order to start it i have to turn of the emergency/kill switch -turn down the thermostat-push in the reset button on the side then turn up the thermostat & it works every time but it shuts off at least once a day--could some one tell me what the problem is or a solution?---that was the original comments & it is the roll out switch, but what is happening is it fires up , then fan cuts in, but it does not go into the second stage but continues to heat up so finally it kicks out (my opinion due to overheating) but when it do kick out the fan continues running even if i turn the thermostat down .
Old 03-20-2012, 03:26 PM   #10
An old Tradesmen
Thats common with a tripped roll out switch.
Old 03-20-2012, 03:35 PM   #11
I found out the problem it is the Secondary Heat Exchanger & it has to be replaced .
Old 03-21-2012, 12:59 PM   #12
and his period key is still broken.
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 10:31 PM
Is this a bad Carrier Infinity installation? Justin1990 HVAC 5 07-22-2011 11:18 PM
Carrier Furnace Problem... cornation71 HVAC 3 12-10-2009 07:52 AM
Carrier Weathermaker 8000, Gas Furnace Problem kiss44 HVAC 1 10-18-2009 08:27 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
