-   -   Carrier Infinity thermostats integrate with control4 2.0 (http://www.diychatroom.com/f17/carrier-infinity-thermostats-integrate-control4-2-0-a-75783/)
Proteco 07-09-2010 06:33 PM
I want to intagrate 3 infinity systems in a house with separate damper system for each infinity, also i want to use the carrier infinity thermostats, i just want to integrate it with the control4 system
I had read that with the SAM you can comunicate with the control4
"The Carrier Infinity SAM drivers allow the Control4 system to work in conjunction with a Carrier Infinity
HVAC system. In order to communicate with the Carrier Infinity system, you must install a System
Access Module (SAM). While the SAM provides both serial and IP interfaces, only the serial interface
provides access to the control protocol. The IP interface is limited to a Web browser. Control4ís driver
utilizes the serial port.
The Control4 system on which you wish to have these drivers installed must be running Release 1.7.0 or later. If youíre not on 1.7.x, contact your dealer to see about an upgrade."
But it doesn't say how to do it.
If anyone wold point me into the right direccion i will be thankful
