-   -   Carrier Infinity Thermostats / Control4 (http://www.diychatroom.com/f17/carrier-infinity-thermostats-control4-8395/)
mistos 05-11-2007 03:00 PM
I have just installed a new Carrier Infinity 4 Zone Air Condition. (3 units 1 with a damper). My dealer is saying that the Infinity thermostats do not communicate with each other and Carrier has not been much help. Does anyone know how these things interconnect and communicate with each other?
We are looking to also have this run and monitored by a Control4 home automation system system. has anyone had any experiance with this as well.
#CARRIERMAN 05-11-2007 07:41 PM
Hi mistos
I am a very experienced person with Infinity systems. In your question it is not real clear what you are dealing with. If you have a Infinity system in your house and a damper system that is compatible with it all you have to do is go into the configuration of the Infinity system and tell it what it is working with. It sounds like to me, either you have selected the wrong company to do your work or you have an incompatable system. Give me some more details and I will stear you in the proper direction. Don't get discourged with the system, you have made an excellent choice. But your choice of servicer may be your problem.
Good luck
Rusty
mistos 05-14-2007 10:52 AM
When we purchased the system I was under the impression that we were able to adjust the temperature, humidity, etc. via any thermostat in the house anywhere in the house. For example if we are in zone 1 and want to adjust the temparature in zone 3 from the zone 1 thermostat. I am being told that I can do that only in the 2 zones that share the system thru dampers.
With that said how does the remote access for the system work? Do I need a seperate controller / wireless account for each system?
Thanks for your help.
mistos 05-17-2007 08:26 PM
Carrierman. Do you have further insight on the infinity cotrolers comunicating with each other or remotely?
Any help would be appreciated
LKJ 12-03-2008 11:02 AM
Carrier Infinity and Home Automation
I am interested in any follow up with regard to Carrier Infinity systems and available home automation controllers. In addition to Crestron, what other systems may control the Infinity system? Thank you!
