Old 12-04-2007, 09:28 AM   #1
Carrier Infinity Thermostat "Staging"
I just got the wonderful Carrier Infinity System. Nice...
58MVB080-14 Furnace, Electronic Air Cleaner, with Carrier N Coil, Lennox 15 Seer Single stage Outdoor A/C and the Infinity Thermostat.
I have a question regarding the thermostat...I can program it for something called "Staging"
I see that it controls the staging of the furnace and can be set to System (Thermostat), Low, High, or Furnace.
I know what the low and high are for, but what would be best for setting. System or Furnace?
Furnace allows the furnace algorithm to control staging.
Which is best???
Adrianjohnm is offline   Reply With Quote
Old 12-04-2007, 07:08 PM   #2
Thoroughbred Mopar Man
Hi Adrianjohnm
First of congratulations on your purchase. To answer your question, don't set any peramiters in your controller as this will limit your furnaces ability to learn. The system you have has an intelligent staging if you let it teach its self. It will learn the required heat load as well as your required cooling load. This will keep your system as efficient as it was designed.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 12-11-2007, 02:20 AM   #3
Yes, I do love the system. It is fantastic. Computerized and learning ability...How cool
Is the Infinity system the only one like that???
Also, I guess with your anser I should keep the Infinity Thermostart on "System" and not put it on "Furnace" , when it comes to "staging"
Thanks for all you assistance.
I love my Infinity!!!
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 07:30 PM
Carrier Infinity Thermostats / Control4 mistos HVAC 4 12-03-2008 12:02 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 04:00 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 03:27 PM
Carrier Infinity Vs. Performance? davidwilp HVAC 2 11-15-2006 01:27 PM
