Carrier Infinity Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2014, 07:31 AM   #1
Carrier infinity thermostat problem
I have a carrier heat pump system in my house and every time the power goes out, the thermostat defaults to a/c when the power comes back on. The settings are still the same but I have to switch it back to heat. My upstairs unit doesn't do this, it just comes back on to whatever it was on. Any ideas?
Dbrian66 is offline   Reply With Quote
Old 01-28-2014, 08:40 AM   #2
Rewards Points: 80
Are they different stats? Does The up stairs have battery backup and the down does not?
List thermostat model.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-28-2014, 08:47 AM   #3
They are the same thermostat. I don't know if they have battery back up or not. I will check that when I get home tonight. All of my settings stay the same. If it was a battery prob, everything would have to be reset right?
Old 01-28-2014, 08:54 AM   #4
Rewards Points: 80
Not sure, just asking to help have mor info for the experts. I have 2 non battery operated stats that return to correct settings upon power failure.
Sounds like yours may have an internal setting different between the two, but just guessing until we get model number and experts here.
I assume you have not called maker?
Old 01-28-2014, 08:55 AM   #5
I'm not sure of the model of the thermostat but I searched the image and all they call it is The Infinity Thermostat Control System.
Old 01-28-2014, 08:58 AM   #6
I have not contacted carrier yet. I checked there web site and did not see a contact us section. Hoping for someone to say " just push this button ..... Etc." LoL
Old 01-28-2014, 09:32 AM   #7
Rewards Points: 80
http://www.homeownershub.com/hvac/re...tat-44956-.htm
Take a look at the above post, get all the way down to the last 2
Tags
carrier , infinity , thermostat
Thermostat Problem loftezy HVAC 4 03-21-2012 05:43 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 05:33 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Thermostat problem vtec69 Electrical 7 11-27-2009 10:07 AM
