Old 06-27-2011, 08:29 PM   #1
Carrier Infinity Thermostat no power
I changed out the condinsation pump and now the carrier Infinity Thermostat has not power, hence the AC will not turn on.
Model 58CVA090-16
Series 140
Have tried turning on and off and on the power to the unit and house.
Have tried pulling the thermostat off the wall and putting it back.
There is power to the AC (orange/yellow steady light).
The new pump works.
Help
klblanchard is offline   Reply With Quote
Old 06-28-2011, 05:33 AM   #2
An old Tradesmen
Check that you reconnected the safety switch wires at the new condensate pump.
Tags
carrier no power, carrier thermostat
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Carrier 8000T Thermostat blank jeffetdiy HVAC 4 02-03-2011 10:11 PM
carrier infinity rns HVAC 5 01-14-2010 11:27 PM
Carrier Infinity 96 Trouble Code 25 travissmith25 HVAC 1 02-16-2009 12:35 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
