Carrier Infinity Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 02:14 PM   #1
I know there is way to access diagnostics through this thermostat. I have a hybrid system and the heating has quit working. I would like to look at the diagnostics to see where the problem may lay. If anyone knows how to get into the diagnostics I would really appreciate being given that information.
PeterG is offline   Reply With Quote
Old 11-14-2009, 10:26 PM   #2
Houston204's Avatar
Rewards Points: 556
Hold advanced for 10 seconds (untill screen changes) scroll to Service and select Last 10 system faults.
Houston204 is offline   Reply With Quote
Old 11-14-2009, 10:31 PM   #3
Houston204's Avatar
Rewards Points: 556
You can also watch the sytem go through it's startup sequence from your stat.
http://s151.photobucket.com/albums/s...nifinity-1.flv
Old 11-14-2009, 10:48 PM   #4
Low Pressure Switch
Thanks for the information. Using this process I have found that the low pressure switch is open. Other information I have received suggests that the port to this switch is regularly fouled with carbon. Heck of a design. Now I have to figure out how to clean it. This must be something that is quite common.
Old 11-14-2009, 11:01 PM   #5
Houston204's Avatar
Rewards Points: 556
If your AC drain has leaked and you have a vertical application it is possible that the pressure switch inlet is restricted (though not with carbon). Do not blow into or suck on your pressure switch. It is designed to measure around .5 inches water column vacuum. 28" W.C. is 1 psi.
That thermostat will display system info, like the model and serial number of your equipment. What furnace model do you have? If it is anything but a 58CVA I suspect that you have a condensate furnace. You might inspect for leaves or some other debris blocking your PVC venting.
Old 11-14-2009, 11:05 PM   #6
Houston204's Avatar
Rewards Points: 556
Condensate furnaces will also lock out on the pressure switch when the furnace condensate drain is plugged.
Old 11-14-2009, 11:09 PM   #7
Furnace
The exact model number is 58CVA090-16. It is a mid efficiency furnace but it is a hybrid system with a heat pump. According to the event summary it appears that the coil has frozen on a couple of occasions. When I talked to a local tech he told me that the ducting in North America is not large enough to support the air conditioning demand I placed on it during the summer. As well, I probably left the filter in too long and couldn't get enough air past the coils, I suspect.
Old 11-14-2009, 11:17 PM   #8
Houston204's Avatar
Rewards Points: 556
That system will display duct static pressure in heat or cool mode, .5 inches W.C. is desired. The video shows how to display duct static pressure in heat mode.
I like that furnace. You will have 2 pressure switches. Pull the rubber hose to the one that displays .33"wc and check for water or rust.
Old 11-14-2009, 11:23 PM   #9
Houston204's Avatar
Rewards Points: 556
If your ducting is to small for your system, I'm not sure that this would reflect the duct size of the entire country.
Old 11-15-2009, 03:33 AM   #10
An old Tradesmen
Rewards Points: 6,550
But a lot of it.
After you change your air filter.
See what static your system is running at.
Old 11-15-2009, 05:45 PM   #11
Houston204 and Beenthere; Thanks for your help on this one. I watched the video again and one thing I had not noticed before was that while you are doing the furnace check you do not have the heat on (the little red LED isn't glowing). Is this necessary to do a proper check? I have run mine with heat on and keep getting a 32 error.
Old 11-15-2009, 06:04 PM   #12
Houston204's Avatar
Rewards Points: 556
Shouldn't matter. Reset power to your furnace and try the test again while you are in front of your furnace. Can you hear the induced draft motor run?
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 02:42 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 09:30 PM
Carrier Infinity Thermostat mikeramos HVAC 3 02-27-2009 11:25 AM
Carrier Infinity Thermostat "Staging" Adrianjohnm HVAC 2 12-11-2007 02:20 AM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 04:00 PM
