Carrier Infinity Systems - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 07:37 PM   #1
Carrier infinity Systems
I have a project which has two Infinity split systems 5 tons. each, could I conect boths in a same head pressure duct system, to handle 16 zones?
xixito is offline   Reply With Quote
Old 07-07-2010, 07:12 AM   #2
An old Tradesmen
Rewards Points: 7,378
Not if they are VS blowers. One will fight the other.
Best to keep them separate.
Old 07-07-2010, 09:16 AM   #3
Infifnity Systems
Yes I know, the VS fan will fight betwen, but, the question is this, the computer, or the mother board, has capabilities to recognize two systems like Comfort Zone II, and name it like system 01 and system 02 and to have 4 stages cooling, including to make the fan cfm setings in accordance with this new arrangement?
Old 07-07-2010, 12:01 PM   #4
An old Tradesmen
You'll end up with expensive motor replacements.
The blowers will fight each other, no matter what your zone control can handle.
VS blowers are not designed to be twinned.
Even PSC blowers are suppose to be set to the same air flow, and run at the same time on any call from the thermostat. Weather its a small zone, or the whole house calling.
Separate the duct systems. Use 2 zone controls. Much cheaper then $2000.00 every few years replacing VS blower motors.
Carrier Infinity Control - anything to cover sides from old horizontal thermostat? misterbill HVAC 5 03-25-2010 09:55 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 08:30 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 04:20 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
