Old 07-22-2011, 05:17 PM   #1
Question
Carrier Infinity shut down, drain is not clogged
Today our carrier infinity totally shut down. Breakers are fine, drain line is fine. Before i call for a weekend service call, any thing I could check out myself? This has happened before. Thermostat is dead. Last time it was a drain line, but this time there is no water in the pan, or the line. So it is not the automatic shut off. We had a thunderstorm earlier. I didn't notice just when the AC went out, but the power did go off for about a minute. When everything just shuts off, I'm baffled!
Kenny48 is offline   Reply With Quote
Old 07-22-2011, 11:25 PM   #2
An old Tradesmen
Check your breakers.
The Following User Says Thank You to beenthere For This Useful Post:
Kenny48 (07-27-2011)
Old 07-23-2011, 11:46 AM   #3
biggles's Avatar
if the stat has no LED display might of tripped the CB on the low side of the TR in the furnace or burnt primary 115V or secondary side 24V..pull stat and subbase... R to C should be a constant 24V with stat in hand if not read head to the TR in the air handler...hope its just the sec. side breaker
The Following User Says Thank You to biggles For This Useful Post:
Old 07-27-2011, 11:20 PM   #4
Well, I checked everything breakers etc.
So I once again decided to play with the drain. I ran some bleach and a lot of water through it. By the time I came down out of the attic, the thermostat was on again and it started running. I don't really understand because there was no sitting water in the drain near the shutoff.
Thanks to all who gave me suggestions on what to check.
Tags
ac unit shut down, carrier infinity, central ac unit, thermostat
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 02:42 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Carrier Infinity 96 heats to slow ryanh HVAC 2 03-11-2009 06:46 AM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 09:30 PM
bathroom clogged drain cwpetal Plumbing 2 06-10-2008 12:03 AM
