Carrier Infinity Fault Message Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 01:20 PM   #1
Rewards Points: 45
Carrier Infinity fault message help needed
I've had a couple of occasions where I awoke in the morning to find a system fault message on my Carrier Infinity thermostat. The most recent message said something like "33 - Limit Fault, 198 Entries Active." I had no idea what this meant, if it was serious, etc. I tried to clear the message from the display but wasn't able to do it. Not knowing what else to try I turned off the power to my furnace and then turned it back on. When I looked at the display the fault message was gone.
I called Carrier support to ask them what I should do in circumstances like this. Basically what they said was that I should call my furnace service company. A call for service will typically cost $80 - $100, and it could get pretty expensive to have to do this each time a message appears.
I'm trying to find out if there are typical fault codes that I can take care of by myself without having to get a service technician. Since the fault code cleared with a power cycle of the furnace I'm trying to find out if that is something I should always try first and then see if the code returns before calling for help. I'd appreciate any information about how to deal with these codes as well as what might have caused a "33 - Limit Fault" and if this is something I need to be concerned about.
rvmeush is offline   Reply With Quote
Old 12-28-2013, 02:03 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,404
poor airflow thru the furnace. dirty air filter, undersized ductwork, closed vents, dirty underside of an AC coil. that can SERIOUSLY damage that furnace and shorten it's life.
Old 12-29-2013, 09:47 PM   #3
Rewards Points: 45
Is there some resource that lists other common issues associated with Carrier fault messages? Having the info you provided is useful for Fault 33 but it would be nice to know what other typical fault codes might mean.
Old 12-29-2013, 10:37 PM   #4
Rewards Points: 163
Do you have a model number of the stat and furnace?
52Caddy is offline   Reply With Quote
Old 12-30-2013, 04:04 AM   #5
Rewards Points: 45
The furnace model is 59TN6A100V21--22 and the thermostat model is SYSTXCCUID01-V
Old 12-30-2013, 09:25 AM   #6
Rewards Points: 163
The only info I found for the stat lists code 33 as "Limit circuit fault AND high heat only is active".
I'm not sure what that means, maybe someone else has an idea. Google SYSTXCCUID01 and you'll see the installation instruction PDF, the fault codes are at the end.
Carrier Infinity condensate backup question. rvmeush HVAC 1 10-04-2012 11:36 AM
Question about Carrier Infinity Media Cabinet rvmeush HVAC 2 09-17-2012 01:23 PM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
Carrier Infinity service message Joe F HVAC 1 07-31-2009 04:53 PM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 07:30 PM
