Carrier Infinity Does Not Work With Control4 Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 04:39 PM   #1
Angry
Carrier Infinity does not work with Control4 Thermostat
I have Carrier airconditioners in the house. A couple of them are the new Infinity systems with Infinity thermostats. They worked just fine. Then I installed a Control4 system in the house. They removed the thermostats for the non-Infinity Carrier systems and from the Infinity Carrier systems. They replaced all thermostats with Control4. Bottom line: the Control4 thermostats work with the NON-Infinity, but they do not work for the Infinity systems.
Carrier has said that only Infinity thermostats work with Infinity systems.
Does this make sense?
o1o1o1o1 is offline   Reply With Quote
Old 02-27-2009, 08:30 PM   #2
An old Tradesmen
Rewards Points: 7,328
Should still have the standard terminals in the equipment. At least the furnaces did.
So someone will have to rewire the actual equipment.
And if its staged equipment, you may need to pull new thermostat wires.
Tags
carrier , control4 , inifinity
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
Where are the "Carpenters" ???? wrldruler Carpentry 14 09-11-2008 07:37 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 07:14 AM
