Old 04-02-2007, 12:01 AM   #1
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat
Planning to have a Carrier Infinity 96 HiEff furnace installed. Installer is recommending the matching Infinity Control Thermostat.
However I also have/own a brand new Honeywell Vision PRO 8000 Thermostat (Model # TH8321U1006). It is a multistage thermostat. Can anyone confirm or deny that the Honeywell can be used on the Carrier?
Installer is saying I can't use it. Just want to be sure. If I can use the Honeywelll since I have it, that would be great.
Comments anyone?
super_man4471 is offline   Reply With Quote
Old 04-02-2007, 07:53 AM   #2
The infinity control (like the unit itself) is very confusing and not very user friendly..........Before you spend all that money, you may want to see one in action somehow............it could save you alot of headaches down the road.
harleyrider is offline   Reply With Quote
Old 04-26-2007, 03:27 PM   #3
We use Infinity controls regularly. Like any other digital thermostat, there is a short learning curve that reading the manual cures quickly.
Your contractor however is both right and wrong! The Infinity is designed and works best, when used as a "System" not just one or two components. In this case, your furnace will work with ANY thermostat, but it will not allow you to have all the functionality of the Infinity System.
The unit is designed to communicate. The control, is more or less a small computer that monitors and adjusts the furnace blower to meet the demands of your existing indoor climate, based on feedback it receives from sensors built into the system.
Duct pressures are monitored - If the filter is dirty, you are notified on the tstat. More importantly, if the pressure indicates a frozen evaporator coil, the unit will shut itself down to avoid compressor burnout etc.
So... Yes, the Infinity gas furnace will work with you HW thermostat, but you will lose of the important features of the Infinity unit. You are spending quite a bit on the unit already, its worth having the Infinity control!
Climate-Pro is offline   Reply With Quote
Carrier Infinity Thermostats / Control4 mistos HVAC 4 12-03-2008 12:02 PM
Carrier Infinity Vs. Performance? davidwilp HVAC 2 11-15-2006 01:27 PM
