Carrier Infinity And Aprilaire 5000 EAC? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2013, 11:24 AM   #1
Carrier Infinity and Aprilaire 5000 EAC?
I have the Carrier Infinity system (59MN7 and 24ANB7) with the Infinity Controller with Wifi. The Infinity TS uses 2 communicating wires and the hot and common wire. The G (fan wire) is not used. How can I connect the Aprilaire 5000 to this unit so that it is active when the fan kicks on? I am thinking that since the G wire is not used, I may need to use a fan sensing relay on the fan wire, but just want to check before going that route. Also, can the Aprilaire be connected so that I can control the fan from the Aprilaire controller (i.e. start fan via the controller without the A/C or furnace running for filtering). Also, I found in the TS service menu that the G wire can be activated for other mechanical devices. Can I connect to the G wire and activate the G wire, via the TS service menu?
Any help or guidance would be appreciated.
Thanks...Al
Methodical is offline   Reply With Quote
Old 07-24-2013, 10:34 AM   #2
Anyone?
Old 07-24-2013, 12:10 PM   #3
Experienced HVAC Tech
HVAC1000's Avatar
Another option would be to get 120v from the EAC terminal on the board in the furnace/air handler. It gives you 120v whenever the fan is on no matter what is calling. If fan on it will run. If you only need 24v put a transformer on the EAC terminal.
HVAC1000 is offline   Reply With Quote
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 05:33 PM
Carrier System Sizing & Advice tballer HVAC 9 09-28-2012 06:25 AM
Humidifier for Carrier Infinity 96 system rvmeush HVAC 1 09-19-2012 07:16 AM
carrier infinity rns HVAC 5 01-14-2010 11:27 PM
Carrier MPV Furnace & Aprilaire humidifier mikeramos HVAC 4 11-21-2008 06:04 PM
