Old 08-03-2012, 04:16 PM   #1
Carrier infinity 96 venting
I need to move an existing exterior vent .The unit is a Carrier 96 infinity and the dual vent terminates on the exterior way to low for the snow we get.What are some suggestions for this as it looks the kit supplied is a complete unit and doesn't look as if it will move easily? Thanks.
Euge
euge is offline   Reply With Quote
Old 08-03-2012, 04:23 PM   #2
It is a kit the inner pipe is outlet the outer pipe is the inlet for the furnace. you can run these in seperate pipes. they then can be elbowed up above snow level and the elbowed back down to prevent rain water getting in. the rain water does not effect the outlet from the furnace but will effect the inlet. They have to be 3 feet apart when done this way. It also does not look the best. you have to use long raidus elbows and non foam core pvc pipe. Each elbow adds the equivilant of 6 feet of pipe so you will need to make sure you are not exceeding the venting distance. The carts are in the installation instructions.
turnermech is offline   Reply With Quote
The Following User Says Thank You to turnermech For This Useful Post:
euge (08-03-2012)
Carrier Infinity thermostats integrate with control4 2.0 Proteco HVAC 0 07-09-2010 06:33 PM
Carrier Infinity Control - anything to cover sides from old horizontal thermostat? misterbill HVAC 5 03-25-2010 10:55 PM
Carrier Infinity does not work with Control4 Thermostat o1o1o1o1 HVAC 1 02-27-2009 09:30 PM
Honeywell TrueSteam with Carrier Infinity Control Llama HVAC 1 02-19-2009 05:20 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 04:00 PM
