Carrier Infinity 96 Trouble Code 25 - HVAC - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 11:25 AM   #1
Hi All,
I am receiving a trouble code 25 "Setup Error" on my Carrier Infinity System. All was working fine until my neighbor's pine tree knocked out the power line.
I am assuming a power surge knocked out the control board. Is that possible? If it's still spitting out a fault code, should it not still be functioning?
Would the fuse not have protected the board?
travissmith25 is offline   Reply With Quote
Old 02-16-2009, 11:35 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Turn the power off to the furnace and set the thermostat to OFF. Wait 5 minutes. Turn power ON. Then try the heat etc. These high end furnaces are particular about how they start up. Yours may need a nice smooth REBOOT.
Old 11-18-2014, 08:37 AM   #3
Rewards Points: 2
My Carrier Infinity 96 is making a rapping noise. Like someone knocking on the door. Not all the time but occasionally. What should I do?
beesboys is offline   Reply With Quote
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Carrier Infinity Thermostats / Control4 mistos HVAC 4 12-03-2008 11:02 AM
Infinity System trouble djd2008 HVAC 2 09-24-2008 06:54 PM
Carrier Infinity HeatPump code 46 SeanWhite HVAC 1 07-31-2008 07:48 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
