Carrier Inducer Motor Screaming - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 01:40 PM   #1
Hello - I have a Carrier Furnace which started making horrible screaming noises when the furnace first starts to run (but before the blowers start). The sound seems to be coming from the inducer but I cant tell if its the fan or the motor itself.
One thing that I find abnormal is that the inducer fan assembly is not held tightly to the motor at all. There is a pin which holds the fan on the 'pin' of the motor, but, the fan can actually move up and down on the pin, which is certainly causing the fan to vibrate significantly (and possibly creating the noise), and its surely also significantly reducing the effectiveness/output of the fan. Is this normal? Shouldn't the fan be held tightly to the pin of the motor so that it doesnt vibrate?
Thoughts? Any insight here would be appreciated.
malhawker is offline   Reply With Quote
Old 12-14-2011, 01:54 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
id say replace the motor
plummen is offline   Reply With Quote
Old 12-14-2011, 04:39 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,038
Ayuh,... Sounds like ya gotta replace the Whole Thing....
Old 12-14-2011, 10:10 PM   #4
Rewards Points: 494
You are lucky if furnace is still working. If fan still closes pressure switch, you'll get heat.
Find the right one here:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
Then order someplace like here
http://www.cshincorporated.com
diyorpay is offline   Reply With Quote
Old 12-14-2011, 10:35 PM   #5
plummen's Avatar
all the ones ive ever replaced came as a unit
Carrier Bryant Draft Inducer Assembly 320725-756 fencedog HVAC 10 11-10-2012 08:16 AM
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help mtom01 HVAC 10 02-20-2011 06:43 PM
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 04:33 PM
Carrier Weather Maker inducer voltages used2beatech HVAC 16 10-16-2009 02:43 AM
Carrier Draft Inducer Problem? ChiTown HVAC 5 12-24-2008 07:16 AM
