Carrier Induced Combustion Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-18-2012, 03:53 PM   #1
Carrier induced combustion gas furnace
If there is a filter at the intake air flow inside the house do I Need one at the furnace located in the garage?
Oscarthomas is offline   Reply With Quote
Old 03-18-2012, 08:36 PM   #2
An old Tradesmen
Rewards Points: 8,174
No you don't.
Do you only have that one return grille.
Old 03-18-2012, 08:37 PM   #3
how
Rewards Points: 1,104
Nope, if you are sure you only have the one return air grill. The issue is always, Does the filter restrict too much air through the ducting? A temp rise test on the furnace and a comparison of the temp rise on the furnace rating plate is the real test.
how is offline   Reply With Quote
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 07:45 PM
Carrier Furnace bmak3 HVAC 1 01-13-2011 06:43 PM
Sealed Combustion Furnace and Tank Hot Water Heater Yippee HVAC 6 06-16-2009 12:32 PM
Zoning With Carrier Infinity Furnace ddartmouth HVAC 1 01-05-2009 11:55 AM
