Carrier HVAC Install Help!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 12:58 PM   #1
Carrier HVAC install Help!!!!
I just had a Carrier HVAC unit given to me. Im trying to install this in my home and I need Help..lol.
The Model Number is 48GS-036090301
What i need to know is what size Ductwork and Return Register to use.
Im installing this in a 14x72 Mobile Home!
Please any help would be Greatly Appreciated!!
JWhite75501 is offline   Reply With Quote
Old 05-22-2011, 06:15 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
is this a package unit? If so then do you already have duct work?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 05-23-2011, 08:31 AM   #3
All I have is the Unit, No Ductwork. Thats the reason I need to know what size to get!
Old 05-23-2011, 08:57 AM   #4
I might be able to help if I knew the CFM's
It looks like you have a 3 ton unit
This might give you some help
http://www.docs.hvacpartners.com/idc...t/48gs-5pd.pdf
It is the product documentation
Says you need a 20x24 return air filter
taqwus is offline   Reply With Quote
Old 05-23-2011, 05:05 PM   #5
An old Tradesmen
Rewards Points: 7,816
What kind of heat does the home have.
carrier fan coil FE4A uplfow position slope coil silica HVAC 0 07-22-2009 12:53 PM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
HVAC Carrier 38chc RWaltz HVAC 2 05-28-2009 11:18 AM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-16-2008 11:25 PM
Carrier furnace fan wouldn't shut off claymthomas HVAC 5 01-21-2008 06:39 AM
