Carrier Hvac Fan Wont Stop Running - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2011, 01:13 PM   #1
Carrier hvac fan wont stop running
I replaced my thermostat and got the wires mixed up. Now the fan won't turn off... do i need to replace the transformer?
jessekblanton is offline   Reply With Quote
Old 10-07-2011, 01:18 PM   #2
JJboy's Avatar
Reinstall the old thermostat and check if something has damaged.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-07-2011, 01:35 PM   #3
The fan probably won't turn off because your thermostat has the fan set to on instead of auto...
jfrotten is offline   Reply With Quote
Old 10-07-2011, 02:04 PM   #4
Rewards Points: 154
Its not the transformer. Check to made sure that the g terminal wire and the R terminal wires arent touching. Sounds like you have the wires mixed up. The best way to resolve this issue is to open up your furnace or air handler and see what color wires are connected to the terminals in the AHU.
Patrick Eubanks is offline   Reply With Quote
Old 10-07-2011, 03:49 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
also check your low voltage fuse on the control board.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
HELP! Electric furnace won't stop running! knchat HVAC 3 12-28-2011 08:38 AM
Carrier Furnace Burner turns on and off continuosly while running Jayenglert HVAC 12 09-28-2011 07:37 PM
running HVAC ducts for newly finished basement room denemante HVAC 3 11-01-2010 05:02 PM
Frigidaire ice dispenser won't stop running jasmine31577 Appliances 6 08-13-2010 02:26 PM
Cut top and sole plates when running HVAC ducts? toddmanqa HVAC 4 11-16-2009 03:13 PM
