-   -   Carrier hvac fan wont stop running (http://www.diychatroom.com/f17/carrier-hvac-fan-wont-stop-running-119452/)
jessekblanton 10-07-2011 02:13 PM
I replaced my thermostat and got the wires mixed up. Now the fan won't turn off... do i need to replace the transformer?
JJboy 10-07-2011 02:18 PM
Reinstall the old thermostat and check if something has damaged.
jfrotten 10-07-2011 02:35 PM
The fan probably won't turn off because your thermostat has the fan set to on instead of auto...
Patrick Eubanks 10-07-2011 03:04 PM
Its not the transformer. Check to made sure that the g terminal wire and the R terminal wires arent touching. Sounds like you have the wires mixed up. The best way to resolve this issue is to open up your furnace or air handler and see what color wires are connected to the terminals in the AHU.
hvactech126 10-07-2011 04:49 PM
also check your low voltage fuse on the control board.
