Carrier Heat Pump Factory Charge ? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-04-2007, 04:15 PM   #1
Siffleu's Avatar
Question
Carrier heat pump factory charge ?
Hi there,
My question is a bit DYI but I hope it's not against forum rules. I got a HVAC guy that will finalize my installation but he didn't know Carrier(he is doing commercial stuff , never installed a carrier residential)
the combo is a 40QNQ018 with a 38QRF018 heat pump
I have done the house myself but I let the HVAC finalize the installation
wiring has been pre-wire by a qualified electrician
refregerant line (5/8 and 3/8 lines) have been pass thru wall by myself 50f of 5/8, 50f of 3/8
got both service manual to give it to my HVAC man who will connect the hosing
I might need another manual because the wall unit manual specify a 6lbs precharged (I tought the precharged was into the exterior unit????)
there also a note the factory charge is based on 25ft of interconnecting line
does that mean I have a total of 100ft and he will need to add gas ? if yes, will he be able to calculate what he need or he need a specific chart from carrier ?
the purpose of all this isn't a DYI, I just want to give everything my hvac man will need to complete the installation because he never done a carrier residential install. I want to be sure he will have everything to do a perfect job.
I've already call authorized carrier installer and none of them wanted to install that because I already own the unit (bought it from carrier directly)
Siffleu is offline   Reply With Quote
Old 11-05-2007, 03:54 AM   #2
Only the outside condensing units are pre-charged....
What gas is it on R410? R22?
How long is your pipe run? mmmm sounds like you want to do it your self to me?
fridgeman is offline   Reply With Quote
Old 11-05-2007, 03:59 AM   #3
just remember ...A tradesman will have and use the correct tools, ie will not pipe purge....vac pump down to at leat 500 microns....this is something you yourself can not do...R410 also opperates at very high discharge pressures and can very dangerous.
Old 11-05-2007, 06:29 PM   #4
Siffleu's Avatar
no !!!
I just prepare everything for my HVAC...
I build the house and bought the 5/8 line (50f) and 3/8 line (50f) and I've done the piping into walls
had the electrical part pre wired by the electrician
pre wired the 18/8 wire info wall
bought and install the exterior unit on the stand
I still need to install the interior unit onto the wall
I will not play with gas.. !(it's r410 )
but I want to be sure the hvac guy will have all info to do the job because I don't think he done carrier residential installation.. (he only do commercial stuff)
Old 11-05-2007, 07:04 PM   #5
Thoroughbred Mopar Man
Rewards Points: 502
Hi Siffleu
I read through your post. I will tell you the straight from the hip answer. If the technician you are using does not know R410 equipment, find one that does! There is only one way to set the charge on this unit, it is by using the sub-cool method as you have to use a expansion valve. To get the proper performance out of this and any piece of equipment made by the Carrier corporation. You have to set the charge and set the proper blower speed. If they do not have the ability to do this for you, you are going to be foolishly spending money. The other thing that must be adressed when dealing with synthetic oils and refrigerants. The system must be evacuated to no more than 500 microns of moisture. In the installation guide you will see the proper method of doing this. I just don't want to see you get ripped off. If you need any further assistance, please let me know.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-05-2007, 08:04 PM   #6
Siffleu's Avatar
thanks for the input !
I will check with him
quick question for you
is it common to have the indoor unit(230vAc) plugged in the same place as the exterior unit in the disconnect box ?
during the construction of the house, an electrician put a 12/2 from the electrical box (using 20amp breaker) to the exterior and also a 14/3 from exterior to the indoor unit.. (in case a need for 120v)
so I've asked few electrician over forums (in my area, so local law apply) and they tell it's ok to plug them into the disconnect box, on the "output" part of the disconnect box
what do you think ?
Old 11-06-2007, 08:48 AM   #7
Rewards Points: 150
R410 Requires special equipment - i.e. manifold gauge specifically for it. If this guy never worked with this type, he likely does not have the proper tools. And depending on where you are, your install might require a residential licenced HVAC tech with R410 certification. A tech who knows R410 should have what is needed and should know what to do.
scorrpio is offline   Reply With Quote
Old 11-07-2007, 04:12 AM   #8
I will be interested to hear the out come.. plzzzz post..
Old 11-07-2007, 07:01 PM   #9
Siffleu's Avatar
I will hook up the indoor unit, connect electricity and control and then call my hvac man
Old 11-12-2007, 05:25 PM   #10
Siffleu's Avatar
almost done and ready for my hvac man....!!!
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
please suggest me a heat pump system. caseym HVAC 7 10-10-2007 06:41 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
heat pump not working kyleGR HVAC 2 05-30-2006 02:35 PM
