Carrier Heat Exchanger - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 11:15 AM   #1
Carrier Heat exchanger
I ahve a carrier commercial unit at my business that has a cracked heat exchanger. Appraently the landlord years ago painted over the model number. Carrier can not seem to match up the unit so I can purchase the heat exchanger. I also have been hearing some crazy numbers in terms of cost. Can anyone give me some advice?
ericcolon is offline   Reply With Quote
Old 01-28-2009, 11:44 AM   #2
JohnH1's Avatar
Sometimes if you look in the electrical compartment on or near the wiring diagrams you can find the numbers. You can also use the compressor numbers to at least determon the tonnage of the unit. I assume this is a rooftop unit and yes the can get expencive. No way to avoid that.
JohnH1 is offline   Reply With Quote
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 09:45 PM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 09:23 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 04:00 PM
