Old 10-15-2010, 12:51 PM   #1
Carrier gurus, I need help wiring Infinity Control
Hello. We currently an Infinity Control that i connected to our 58MVC furnace using the 4 wire ABCD bus, we also have a 5/1/1 White Rodgers t-stat using 3 wires (RC,Y,G) to control a separate non comunicating single stage split ac system.
We would like to consolidate into a single thermostat using only the infinity control to program both systems. From what i understand by reading the Carrier manuals that i have to wire our AC system into the 24v terminal block located in our 58MVC furnace. However since i have a split system my air handler uses the G terminal, Do i connect the ac system with all three wires using the C Y G terminals? Or would connecting all three wires to the 24v terminal block turn the air handler fan on when the heat kicks on? Or should i jump G and Y together and connect only to terminal Y on the furnace 24v terminal block?
Also do i bypass the transformer on the air handler and connect everything straight to the 24v terminal block on the furnace?
Thank you in advance, your help is greatly appreciated!
nyrangers is offline   Reply With Quote
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 05:33 PM
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 02:42 PM
carrier infinity rns HVAC 5 01-14-2010 11:27 PM
Carrier 8000TS Control Bd Fuse blows EAP HVAC 2 08-28-2008 09:07 PM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 06:02 PM
