Carrier GFA Turns Off And Restarts Sequence After 6 Min - HVAC - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 09:47 PM   #1
Carrier GFA Runs for 6 Min. then Turns off and restarts
Our Carrier 58stx070-12 installed in 2005 is acting up this season.
New filter
It starts normally when the therm tells it to start and runs for about 6 min. 30 sec. Then the fan shuts off, the draft inducer motor starts up immediately, a short time later the burner ignites and fan starts normally for another 6 min. 30 sec. when it does it again.
Since it starts right back on I'm assuming the therm is working ok since it's still telling it to turn on. Am I correct?
Any ideas what problem may be?
Thanks, Ron
Ron997 is offline   Reply With Quote
Old 11-20-2011, 10:00 PM   #2
Rewards Points: 614
are you to hot ,,,
carmon is offline   Reply With Quote
Old 11-20-2011, 10:03 PM   #3
Too hot? I don't understand. Do you mean is it overheating? how would I know?
Originally Posted by carmon View Post
are you to hot ,,,
Old 11-20-2011, 10:04 PM   #4
Rewards Points: 614
sorry thats not what i meant,, is your home comfortable
Old 11-20-2011, 10:09 PM   #5
well it turns off before it reaches the temp it's supposed to turn off at. It starts, turns off after 6 mins, turns back and keeps turning off and starting back up every 6 mins or so until it reaches the temp on the thermostat it's supposted to turn off. then it turns off normally and doesn't turn back on until the temp drops and it's supposed to.
Old 11-20-2011, 10:12 PM   #6
Rewards Points: 614
something seems funny,,,, i would suspect the thermostat may be acting up ... providing all is well with your furnace it is the stat that tells it to turn on and off
Old 11-20-2011, 10:20 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Bypass the stat by turning stat off and in the furnace itself on control board jump r to w terminals, calling for heat. If it stays running than the stat is your problem.
Doc Holliday is offline   Reply With Quote
Old 11-20-2011, 10:23 PM   #8
Rewards Points: 614
oh man thanks doc i should of said that
Old 11-20-2011, 10:36 PM   #9
Thanks I'll try to find it and try it
Old 11-21-2011, 11:29 AM   #10
Ok bypassed the stat and it still turns on and off does it. Any suggestions what it could be?
Old 11-21-2011, 11:34 AM   #11
A resettable high temperature limit switch, a flame sensor (possibly dirty), or the call for heat is dropping out via the board. It could be the pressure switch is opening up as it's running. Possibly restricted burner orifice.
Does it drop out only in heating mode or in cooling as well?
Is the board giving any flash codes at all when it drops out?
Old 11-21-2011, 11:34 AM   #12
sounds like its cycling on the high limit......is your filter clean?
harleyrider is offline   Reply With Quote
Old 11-21-2011, 11:50 AM   #13
thanks for the suggestions. no codes, its didn't do it when cooling, and fresh filter.
anything else is beyond me so I guess I better call someone.
Ron
Old 11-21-2011, 12:21 PM   #14
Good luck and let us know what it turns out to be.
