Carrier Gas Pack Won't Ignite, Pressure Switch Doesn't Close - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 06:17 PM   #1
Carrier gas pack won't ignite, pressure switch doesn't close
Don't know the model number but its an 18 year old, 3 ton package system that I'm going to replace soon. System was working fine, then yesterday found fan running but no heat. Found fan wheel had rusted and broken off of the inducer motor, replaced fan wheel but still won't ignite because pressure switch isn't closing. If I jump pressure switch, burner will ignite but soon shuts down because roll out switch opens (didn't start without access panel in place). Seems to be air flow problem but can't find anything clogged, cracked, broken or otherwise degraded and it was working fine a couple of days ago. The new fan wheel is correctly installed and the inducer motor seems to be working fine. Any thoughts? Thanks!
TNFrank is offline   Reply With Quote
Old 12-01-2010, 07:46 PM   #2
HVAC / Plumbing
18 yr old carrier probably cracked or hole rusted through somewhere
kenmac is offline   Reply With Quote
Old 12-01-2010, 09:39 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
big chance the heat exchanger has a hole in it. or something is blocking the vent. there is a reason why the p/s is not closing
hvactech126 is offline   Reply With Quote
Old 12-02-2010, 05:42 PM   #4
Thanks guys, its clearly time for a new one!
pressure switch is open slowplayed28 HVAC 2 10-31-2010 09:43 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Pressure Switch Stuck Closed --heat works but A/C doesnt assassinmunky HVAC 0 06-23-2009 03:49 PM
Comfortmaker RPJ - 3 Flashes - Pressure Switch Contacts Open olgranddad HVAC 9 02-21-2009 04:07 PM
