Carrier Gas Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 03:03 AM   #1
Angry
carrier gas heater
Hi,My gas heater is just stop working.Now the blower is keep running all the time no matter i turn to heat or ac.Normally when i put the thermostat to heat the furnace on for few seconds than the blower is running.Please help me any body.Thanks alot
trieuphu99 is offline   Reply With Quote
Old 04-06-2010, 06:17 AM   #2
An old Tradesmen
Rewards Points: 6,550
Is/was your air filter dirty/plugged?
Might be off on its high limit. When was the last time you changed/cleaned your air filter.
Old 04-06-2010, 10:33 AM   #3
carrier gas heater
My filter is brand new. The high limit sensor how is it work? when is it contact and when is it not contact? How can i test the high limit?Thanks Pro.
Old 04-06-2010, 03:52 PM   #4
An old Tradesmen
The high limit is to be closed when ever the temp is senses is below its trip point.
It only opens when the air temp is TOO hot.
An ohm meter will tell you if its open or closed.
How dirty was your old air filter you just changed out?
The Following User Says Thank You to beenthere For This Useful Post:
trieuphu99 (04-07-2010)
Old 04-07-2010, 01:03 AM   #5
Thanks.I got it fixed.Again,thank you so much for help.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Carrier Heater just quite hmmmm msan HVAC 5 05-19-2009 03:53 AM
Blown fuse in Control Panel of Carrier Heater jacksup HVAC 3 02-26-2008 06:02 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
