Carrier Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 09:29 PM   #1
Carrier furnance
I HAVE A CARRIER FURNANCE THAT KEEPS LOCKING OUT. I replaced the board, hot surface ignitor, and pressure switch. at each of these points of replacemant the furnance runs fine for about one day. Then I have to , or my wife has to turn the emrgency shut-off to off then to on off-to-on, a few times then it runs for a day or night and then we're back to the same thing. please help!
earl kay is offline   Reply With Quote
Old 01-13-2011, 10:20 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Have you watched the system while starting to heat? Have you noted what it is or not doing or what it is getting hung up on that is causing the lockout? Have you cleaned your flame sensor? Have you replaced your filter?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-14-2011, 05:49 AM   #3
An old Tradesmen
Rewards Points: 6,516
Look to see if it has an error code LED, if so look to see what code its flashing before you turn the power off next time it locks out.
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 01:07 PM
Carrier Hi 90 Furnance variable speed motor ahenderson HVAC 0 12-18-2010 08:28 AM
Sizing New Carrier 58HDV Furnance PortlandGuy HVAC 1 11-14-2010 01:04 PM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
