Old 09-15-2007, 12:08 AM   #1
Default Carrier Furnaces
I am a HVAC service tech and am wondering if there are any Carrier servicemen out there who can tell me why Carrier/Bryant make their equipment so hard to work on. I don't mean complicated (although they are made more complicated then they need to be) I mean why do they stuff simple parts in spots where they bring out cuss words when you try to work on them. Parts as common place as a carbide ignitor are often buried behind many other parts. In my experience, simplicity and ease of service make a better product. There aren't many products worse than Carrier/Bryant. Comments?
ruudman is offline   Reply With Quote
Old 09-15-2007, 12:57 AM   #2
I am not a hvac man but I was looking over my two old Bryant equipment and yes the furnace does appear complicated but thats progress in the name of the cheapest dollar. But the complications can double up if the certified (by Bryant) installer does not know how to troubleshoot the solid state circuitry.
This knowledge and equipment to test the circuitry is needed in todays furnace controls and thermostats. In my particular situation, the thermostats commands are not being followed and relayed to the AC compressor. I believe the companys that manufacturer/distribute AC/Heating equipment should make sure all their dealers stay on top of the new technology thats built into these units by providing troubleshooting manuals for these high end models that have many menu choices on the thermostats and in the furnace controls.
Just following instructions on the install booklets, no matter how well the install goes, does not make a good dealer/installer. He must be provided with the tools to go beyond the AC/Heating education that he possess's and have a good working knowledge of solid state circuitry. My installing dealer technicians would not even go near the electronic controls and now the field manager for Bryant and the dealer are coming back to troubleshoot the system beyond putting gages on the compressor lines.
So your complaint is a valid one, but as a consumer, I believe things are going to get worse for us because many out there are good installers but lacking in good troubleshooting knowledge. As these new systems replace the older models, there going to be a need for continueing education not only in AC technology but also in the solid state circuitry built into these units.
rjordan392 is offline   Reply With Quote
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Next is air conditioning. You see the bracket there on the top there; it's bolted to the right side... Read More »
For the next clip, we're going to go over the Platinum Compressor. The Platinum Compressor, basically, is another compressor that's on Logic that is pretty good. I use it a lot. It has a couple of different options that you can switch from. So what we're... Read More »
Hi, my name's Kip and I'm here on behalf of Expert Village. And this clip we're going to go over a simple technique to begin to troubleshoot when we're having an audio problem and often times that problem is related to our cabling. Let's say, for... Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Carrier Infinity Thermostats / Control4 mistos HVAC 4 12-03-2008 01:02 PM
Payne Furnaces mick6311 HVAC 1 06-26-2007 11:10 PM
Carrier Infinity Control VS Honeywell VisionPRO 8000 Theromostat super_man4471 HVAC 2 04-26-2007 04:27 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 09:49 PM
Help please! What is wrong w/ my Carrier AC? chicagogirl HVAC 3 10-18-2006 06:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
