Carrier Furnace Problems..still - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 09:18 PM   #16
it might be a temp control like that, but i don't think so. when i finally got the burners to come on the fan came on and ran for a moment even though the furnace was cold. then the burners come on and the fan goes off. after about a minute the fan comes on again and all seems normal
thank you for your time and help on this , i greaatly appreciate it.
kevin
kevinp is offline   Reply With Quote
Old 10-21-2008, 09:22 PM   #17
HvacWiz's Avatar
Rewards Points: 252
Well...like I said, i dont think i have an answer for you on that one, but I am glad you have heat now.
HvacWiz is offline   Reply With Quote
Old 10-21-2008, 09:25 PM   #18
thanks haha me too !
Old 10-21-2008, 09:26 PM   #19
i think since i replaced the t-stat and the fan control board that the issue is somewhere there
Old 10-22-2008, 07:40 AM   #20
30 year tech
hvac122's Avatar
Did you find out what tripped the limit? These are safety devices and don't usually trip for no reason. You could still have a safety issue that needs to be looked at. Which limit was tripped?
hvac122 is offline   Reply With Quote
Old 10-22-2008, 09:32 AM   #21
the damper safty switch. it tripped and the curcuit breaker tripped when my wife was playing with all the controls..just sliding them here and there cuz she had no idea how to work the thermastat. had never had a problem till then. i heard her rapidly sliding and turning all the switches every which way.
cleaned everything inside and oiled the motor. i even put the other fan control panel back in but the same thing. fan comes on. then the burners, and the fan stops. after a minute or two the fan comes on and it works ok.
Old 10-29-2008, 05:35 PM   #22
Is the flame blue and strong flame in lp or not? If it is not blue and strong may not have enough heat to heat switch to make it light.
simpleman1962 is offline   Reply With Quote
Old 10-29-2008, 07:51 PM   #23
Alot of Carrier models have a 90 sec. fan run before the burners kick on. Then there is time for things to heat up before the fan kicks on again.
Rookietinner is offline   Reply With Quote
Old 10-29-2008, 10:04 PM   #24
thanks for your inputs
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Carrier 58MXA furnace problems bush HVAC 5 12-12-2007 08:42 PM
furnace and or electrical problems tuasoi General DIY Discussions 4 11-29-2007 12:50 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 09:48 AM
