Carrier Furnace Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 03:58 PM   #1
Carrier furnace problems
Hey Folks:
Quick question for you. I am in need of some Carrier furnace troubleshooting. I am typing from work so don't have the model number.
I came home and turned on my A/C last night. This was the first time I used it in two months. The A/C came on, but the blower never turned on in the furnace. I went down to look at the furnace and I can tell the A/C is working because the side of the furnace is freezing cold. I looked at the LED and noticed flashing LED light. The error I was receiving was 12.
I decided to turn on the heat to see if the problem only existed with the A/C. The furnace (both the blower and the gas ignition) turned on for roughly 2-3 minutes and then shutdown. The error code this time was 33. The weird part was even though the blower was on there was no air coming from any of the vents. I checked both upstairs and downstairs.
Turning the termostat to fan ON does not actually turn the blower on.
I am at loss of what the problem might be. Does anyone have a clue on how I can further diagnose the problem?
Thanks,
Claude
BigK75 is offline   Reply With Quote
Old 07-30-2009, 05:16 PM   #2
Check your filter first even though it does seem related.
You could have a bad run Capacitor, blower motor or furnace board..
If I was on your job I would run each speed on the motor separately just to elinate other problems as a possibility.
hvaclover is offline   Reply With Quote
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Problems with Carrier Furnace circa 1990 Blue2 HVAC 4 11-27-2008 06:32 PM
carrier furnace problems..still kevinp HVAC 23 10-29-2008 10:04 PM
Carrier furnace problems thall860 HVAC 4 10-27-2008 07:29 AM
