Old 11-11-2008, 07:01 PM   #1
Carrier Furnace Problem
I have a carrier furnace model 58SX-060-GG-1 series 190.
My problem began when condensation shorted out the circuit board and the draft inducer motor. I replaced the circuit board and motor but during startup the pilot would light and when the furnace would go to start the blower motor it would blow the ATO 3 fuse. I called a technician and he stated that it may be the wiring harness because it had a bad fitting. I replaced the harness but am having the same problem.
Can anyone help!
Boats1183 is offline   Reply With Quote
Old 11-11-2008, 07:41 PM   #2
are u sure its completely dry on the circuit board? if yes the low voltage side of the fan control on the board is most likely bad which means youll need to rpl the board also
kennzz05 is offline   Reply With Quote
Carrier furnace problem? 4merfigur8er HVAC 15 11-08-2011 11:06 AM
carrier furnace problem dqdave1 HVAC 14 02-06-2010 05:57 PM
Carrier furnace problem 4merfigur8er HVAC 1 01-19-2008 05:47 PM
another Carrier furnace problem jhrodd HVAC 5 02-18-2007 01:09 AM
