-   -   Carrier Furnace Problem (http://www.diychatroom.com/f17/carrier-furnace-problem-31687/)
Boats1183 11-11-2008 06:01 PM
I have a carrier furnace model 58SX-060-GG-1 series 190.
My problem began when condensation shorted out the circuit board and the draft inducer motor. I replaced the circuit board and motor but during startup the pilot would light and when the furnace would go to start the blower motor it would blow the ATO 3 fuse. I called a technician and he stated that it may be the wiring harness because it had a bad fitting. I replaced the harness but am having the same problem.
Can anyone help!:(
kennzz05 11-11-2008 06:41 PM
are u sure its completely dry on the circuit board? if yes the low voltage side of the fan control on the board is most likely bad which means youll need to rpl the board also
