Carrier Furnace Not Working Help - HVAC - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 12:52 AM   #1
Carrier furnace not working help
Hello I have a carrier furnace from the 90's and it won't work. I have a error code 34 then goes into lock out error 14. The firnance seems like it tries to light the heating element gets all bright then dies does it threw times then. It goes into lock out mode for awhile it was randomly working when it wants to now nothing. I have tried cleaning the flame sensor with sand paper no luck what should I do ?
Daviidfm is offline   Reply With Quote
Old 02-29-2012, 07:52 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 398
do you have other gas appliances and do they work/getting gas? gas meter ON? check for 24 volts AC at the gas valve after a few seconds and when the igniter is glowing. if none then the circuit board may be faulty.
Old 02-29-2012, 08:07 AM   #3
I have a Gas fireplace that won't lite but my gas stove and water heater work. the fireplace used to work.
Old 02-29-2012, 08:29 AM   #4
Old 02-29-2012, 10:57 AM   #5
how
Rewards Points: 1,104
As Yuri suggests
When the igniter is glowing, is the gas valve receiving 24V ac.
If not, then the board may be faulty.
If the valve is getting 24V and not opening then the valve is probably faulty.
how is offline   Reply With Quote
Tags
carrier error code 34
Carrier Gas Furnace - Problems with Ignition jean004 HVAC 33 01-17-2012 01:26 AM
Carrier Furnace and Aprilaire not working meanj22 HVAC 3 01-03-2012 09:29 PM
Carrier Furnace code 33 @ startup blower fan sounds like jet Frank Ottawa HVAC 6 04-19-2011 07:12 AM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 05:16 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 09:48 AM
