Carrier Furnace Not Crusading Today - HVAC - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 08:36 AM   #1
jnl
Carrier furnace not crusading today
I woke up this morning to my furnace running but not blowing any heat . At the beginning of winter I had cleaned my thermocouple with emery cloth because it wasn't staying lit. That worked great. Today the igniter and and small fan above is not firing. The blower motor is working and moves air to vents its just cold. Any ideas?
Sent from my GT-N8013 using Tapatalk
jnl is offline   Reply With Quote
Old 02-15-2014, 10:05 AM   #2
An old Tradesmen
Rewards Points: 7,794
Check for a blown low voltage fuse.
Old 02-15-2014, 10:07 AM   #3
jnl
Thanks I will check.
Sent from my XT907 using Tapatalk
Old 02-15-2014, 11:52 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 100
post pics of it with both doors off and the circuit board. there were several versions of that unit.
Old 02-16-2014, 05:11 AM   #5
jnl
I called the HVAC guy out to look, he diagnosed it is circuit board. I watched him check all the fuses and double check. I guess not the worst news.
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 22 04-25-2017 03:02 PM
Carrier 9200 Weathermaker furnace leaking Feathergreen HVAC 5 04-02-2013 04:41 PM
Carrier Furnace bmak3 HVAC 1 01-13-2011 06:43 PM
Carrier Gas Furnace 92 Comfort-No heat. rmjr77 HVAC 4 01-20-2010 03:14 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 09:48 AM
