Carrier Furnace, No Ignition Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 01:44 PM   #1
Carrier furnace, no ignition problem
Carrier furnace 9200 series, ignitor glows, no flame on??
gdnt is offline   Reply With Quote
Old 12-24-2011, 02:02 PM   #2
Not getting gas test to see if gas valve has 24 volts after ignighter glows should also click when opens
firedave19 is offline   Reply With Quote
Old 12-24-2011, 03:37 PM   #3
do you hear a "click" just after ignitor glows?if not then the gas valve is not energizing.....if you do, then its a bad valve, but the only way to tell for sure is with a volt meter
harleyrider is offline   Reply With Quote
carrier 58mvp ingnitor part #/ignition problem GEAF HVAC 8 01-02-2011 05:00 PM
carrier furnace problem dqdave1 HVAC 14 02-06-2010 05:57 PM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 07:41 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 08:53 AM
carrier 58SX ignition problem typhoon55 HVAC 5 06-08-2005 10:18 PM
