Carrier Furnace With No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 07:44 AM   #1
Carrier furnace with no heat
I have a 10 year old Carrier furnace and the blower kicks on with no heat and keeps running?
TROSLINSKI is offline   Reply With Quote
Old 02-02-2010, 09:09 AM   #2
HVAC Tech/ Browns Fan
check glow plug
Tator1076 is offline   Reply With Quote
Old 02-02-2010, 09:14 AM   #3
I appreciate the info. I did remove the glow plug and the ceramic and all looked normal with no cracks.
Old 02-02-2010, 05:08 PM   #4
Check the main limit switch. It maybe stuck open. Just take it out and soft drop it on the floor and put back in. If that work may need to replace it. You can even jump that too,.
Old 02-02-2010, 05:26 PM   #5
An old Tradesmen
Rewards Points: 6,914
As a test only.
Can't leave it jumped out.
Need to find cause of limit opening. They only open when there is a problem.
Old 02-02-2010, 11:30 PM   #6
Rewards Points: 256
furnace died
here are some suggestions i had the same problem it was mostly dirty...
oldrivers is offline   Reply With Quote
Old 02-03-2010, 08:16 AM   #7
Also check up top of the furnace. There is a reset limit too.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 12:57 PM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 08:56 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
