Old 10-30-2009, 07:52 PM   #16
Yuri:
You asked if I installed it. Unfortunately, NO. Rather, 2 incompetent knuckleheads with "licenses" to install them did so, and they were worse than Laurel & Hardy in getting them to do it right. Installed the filter access slot facing the back of the heater in the closet, ran the flex line in front of the heater so we have to work around that when servicing, and on and on.....but I digress.
ccoulter is offline   Reply With Quote
Old 10-30-2009, 07:57 PM   #17
Wiz:
Can you tell me what those LED codes translate to? 14 & 34 on the Comfort 80.
Old 10-30-2009, 08:11 PM   #18
old pro
Yep. I concur. Had lots of problems with the TUA`s. Have to remove and wash the burners to get crud out of the internals or gas won`t get picked up by the crossovers. The code has to be on the inside of one of the doors or in the owners manual. Post the complete model number and a pic of the burner area.
Old 10-31-2009, 07:22 PM   #19
Spiders cause all kinds of problems around here. Dang things love to make webs and egg sacks in orifices and crossovers. A good cleaning and you should be good to go.
Marty S. is online now   Reply With Quote
Old 10-31-2009, 10:41 PM   #20
Default Error #'s 14 & 34 - Carrier is touchy feely sensitive
Yessir!! Well, after removing the gas valve/manifold assy., though the jets were spot on clean, I blew the thing out heavy duty w/compressed air after removing the jets, put it all back together, blew out the cross-overs and we're fine. Never saw a speck of anything come out, but, hey, these things are just WAAYYY touchy feely!!
Thanks to all and we're done!!!
CC
Old 11-01-2009, 10:45 AM   #21
old pro
Alls well that ends well. Glad you got it going.
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
Carrier furnace help code 13 mudtruck HVAC 5 04-09-2008 12:47 AM
Carrier 58MXA furnace problems bush HVAC 0 12-27-2007 11:22 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 02:00 AM
Carrier furnace help code 13 mudtruck HVAC 0 10-11-2007 12:51 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 11:48 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
