Carrier Furnace: Gas Heating Lockout - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-10-2008, 10:26 AM   #16
Lightbulb
Thank you to all on this thread!
You all just saved me from making a service call. My Carrier Weather Maker 8000 has not been functioning for the past week in the furnace function. Not an immediate problem as nights have not been too cold, but I was not looking forward to having it serviced and repaired financially.
But I finally did a search and found this thread and some other sites. I was concerned that I too might have a bad circuit board. Hmm.. more reading at other sites and the information sheet on the furnace made me realize that I needed to try the following before doing anything else -
- set thermostat to lowest setting
- power off to the furnace
- open the furnace
- clean the dust buildup that I felt comfortable reaching
- check connections
- close the furnace back up
- wait (one site said 3 hours - I waited one hour)
- set thermostat to desired temp
- listen to the furnace start a heating cycle (if that doesn't happen, you need to recheck your LED for the error code)
Once again, thank you to inspiring me to try a few things first before calling for service!
Michael
Micked1 is offline   Reply With Quote
Old 06-11-2008, 03:34 PM   #17
I has a similar problem with the Control Board on my 373LAV Model Unit.
A technician came out and qouted me over $550 to replace the CB plus more if the motor was bad.
I was able to have a neighbors HVAC person verify the unit needed the CB plus 2 lbs of freon. This technician actaully called me with the news that his sources were overcharging for the board and that if I could locate it for cheaper, he would install it. I took him up on the challenge/offer and locate dthe board from an HVAC person in another state (not as hot as Texas) and was able to get the replacement get for a decent price (less than $100). I called the technician back out and he took about an hour replacing the CB and my unit work flawlessly now.
Total cost of first trip w/ 2lbs of Freon $100.
Installation ($100 plus part $60).
Total repair was $260 vs. initial $525 estimate.
It pays to consult the professionals, but to also get a 2nd opinion.
cowboys2000 is offline   Reply With Quote
Old 02-17-2017, 05:41 PM   #18
Rewards Points: 4
Re: Carrier Furnace: Gas Heating Lockout > Part
Hello Guys,
Can anyone help with obtaining correct part number for Main Control Board?
I have Carrier 58MXA120 F-15120
ChairDoc1 is offline   Reply With Quote
Old 02-17-2017, 05:43 PM   #19
Rewards Points: 4
I'm not getting any codes but unit is blowing luke warm heat and main compartment is getting crazy hot too.
Old 02-17-2017, 06:31 PM   #20
Rewards Points: 7,186
Originally Posted by ChairDoc1 View Post
Hello Guys,
start another thread.
the board itself should have a model number.
you may want to see if icm makes a drop in replacement because carrier oem parts may be very expensive.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is offline   Reply With Quote
Old 02-17-2017, 06:55 PM   #21
Rewards Points: 46
Latest part number is 325878-751 for the Circuit Board
It doesn't sound like the board, you should start your own thread like user said.
Cheers!
supers05 is offline   Reply With Quote
Carrier Furnace - out cold :) cheddarhead HVAC 30 04-23-2012 01:23 PM
another Carrier furnace problem jhrodd HVAC 5 02-18-2007 01:09 AM
need help with carrier furnace TJ1960 HVAC 9 02-15-2007 12:02 AM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
Lockout - check furnace. newbie102 HVAC 2 07-10-2006 07:50 PM
