Carrier Furnace Flame Rollout Keeps Tripping - Why? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 11:51 AM   #16
biggles's Avatar
remove the flue pipe nearest the heat x and run your finger inide it look down into the exchanger
Old 10-08-2011, 11:59 AM   #17
The flames not not seem to waver when the fan comes on but at least one flame jet seems almost mis-aligned so that not all of the flame is getting into the heat ex. There is some rust on the ports where the flame comes out and perhaps flame is leaking out there? I'm talking about the metal tubes, not the brass nozzles.
Billyv is offline   Reply With Quote
Old 10-08-2011, 12:01 PM   #18
Biggles:
Sorry do not understand. What do you mean by flue pipe nearest the heat exchanger? Thanks for your help
Old 10-08-2011, 12:23 PM   #19
This is what the flames look like whether the fan is blowing or not.
Old 10-08-2011, 01:01 PM   #20
biggles's Avatar
anything yellow is starving for air check those air adjuster if you have them where the nozzle is...that yellow one is producng soot.that flue is where the burnt gases rise up and out should be on top and a ducted 4" or so pipe going out even down the line from the burner...just want to see if you have soot tripping down the pipe..like on your car exhaust
Old 10-08-2011, 01:14 PM   #21
Disconnected the exhaust pipe and there was a bit of water and it is a bit dirty(sooty?). there is no adjustment for the air/propane jets they are just wide open flutes. Any other way to improve combustion so that all 4 ports are blue flames?
Old 10-08-2011, 01:37 PM   #22
JJboy's Avatar
If the flames is shaking check for heat exchanger leak
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-08-2011, 02:02 PM   #23
This furnace has a problem with the secondary heat exchanger failing and I have worked on many of them. Although the heat exchanger suffers from a manufacturer's defect, the real problem is improper commissioning (or lack of commissioning). There are three simple things you can do:
1)Feel the top of the furnace when it's running. It should be warm, but not hot.
2)Remove the hoses from the trap. There should only be clear "water". If there is brown sludge, then the secondary heat exchanger is probably plugged. Also, the hoses should should feel firm, not flimsy and soft. This is also a good indicator that the heat exchanger is plugged.
3)Pull the blower (5/16 hex head screws) and inspect the secondary heat exchanger. You should only see smooth metal. If it's plugged, and corroded through, you will see small brownish red balls or globs on the outside of the fins.
If you observe any of this, I can advise you further on what to expect from a repair. There are certain things which usually need to be replaced with the heat exchanger, so if the company has to travel far to get to your cottage, then it would be best if they brought them with, to avoid having to go back.
hvac benny is offline   Reply With Quote
Old 10-08-2011, 03:02 PM   #24
An old Tradesmen
Rewards Points: 6,124
Its probably one of the Carriers with the defective secondary heat exchanger. Carrier got sued over it. Not sure your covered under the suit, since you bought it used, and moved it from its original installation location.
Old 10-08-2011, 03:37 PM   #25
JJboy's Avatar
SO what is the problem with Carrier secondary heat exchanger?
Old 10-08-2011, 03:51 PM   #26
An old Tradesmen
http://www.omaha-home-inspection.com...y-furnaces.pdf
The Following User Says Thank You to beenthere For This Useful Post:
JJboy (10-08-2011)
Old 10-08-2011, 04:34 PM   #27
While the material that Carrier used was poor, the real problem is poor installs. It's sad to say, but the majority of furnaces being put in today are simple hooked up to ducts, gas, electric and thermostat, then simply fire up while the contractor collects his payment and loads his tools into the truck. Of the 100 or so Carrier heat exchangers that I've replaced, ALL were the result of the installer not commissioning the furnace upon start-up/ poor installation. I've run into countless numbers of techs who think that simply checking the manifold pressure is enough. Hell, I've had to teach techs with 20+ years how to clock an appliance. The worst example that I've come across was a 100 MBTUH three stage Carrier furnace that was over firing by 20,000 in each stage! The company that installed it kept replacing the roll-out switch, without looking for the cause of the failure. By the time I got called to look at it both heat exchangers were toast, as well as about $500 in other components. There are far too many people doing work without gas tickets, as well as too many people with gas tickets who shouldn't have them in the first place.
Old 10-20-2011, 08:48 AM   #28
Finally back at cottage. Thank you hvacbenny. The top of the furnace does get too hot to touch after running for a while. I removed the blower and attached is a picture of the fins. They look pretty clean. Do they look normal to you? The second photo is of the very back of the furnace and looks like water has been dripping from the very back. Does that mean cracked heat exchanger? You mentioned you might be able to tell me what else to look for or what other parts to have the contractor bring?
Old 10-23-2011, 05:27 PM   #29
It's hard to tell from your pics, but from the lower pic, the fins on the left look like the may be corroded through. Water leaking from the back is also common with plugged secondary heat exchangers, as the coupling box rots through. Since your furnace is in a cottage, I'd assume that it's probably not in as bad of shape as a similarly aged furnace with the same problem. If I were the service company, and had to travel quite some distance to you, I'd, at the very least, bring a coupling box kit (coupling box and cold spot baffle) as well as some extra hoses for the pressure switches along with a new secondary heat exchanger. How did the trap look?
Old 10-24-2011, 09:48 PM   #30
Well thanks everyone for your help! I was able to troubleshoot and eliminate a number of items. In the end, the secondary heat ex was quite restricted with gunk and had minor perforations and leaks. With the help of a contractor we pulled the whole thing out and verified this. So I am awaiting a quote for a new heat exchanger and a new furnace and suspect I will choose the new furnace. I am looking for a good quality unit that will not get used a whole lot but I want it to last a long time. What is a brand that will deliver good service at a good price? - don't need bells and whistles, just need to keep the pipes from freezing and provide basic heat when I turn it on the couple of times we go up in the winter.
Trane Gas Furnace - blower on but no flame at burners herbert8101 HVAC 2 09-24-2011 09:23 PM
Trane XE 80 Furnace - flame out and restart Thome HVAC 3 10-12-2009 06:27 PM
gas furnace flame rollout Yoyizit HVAC 45 09-17-2009 09:06 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
