Carrier Furnace - Fan Doesn't Turn Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 06:01 PM   #1
x47
Carrier Furnace - Fan doesn't turn off
I have a Carrier furnace Model #58SE075-3, I see a date of 1975.
The fan is always on; it can only be turned off by turning off the 110v switch on the wall. When I turned it off for a while and then turned it back on, the fan would work normally for 10-12 hours, then the fan would stay on. After doing this several times, now the fan always stays on regardless - it can only be turned off by turning off the 110v switch.
The flame and the burners come on fine, but when the set temperature is reached, the burners turn off and the fan keeps going, blowing cold air.
I jumped and disconnected the high limit switch (#HH12ZA251), but the fan kept running when jumped or disconnected, so I assume that the switch is good.
The control board is 302075-302.
Any ideas on what it could be? I am hoping for a low cost fix
x47 is offline   Reply With Quote
Old 11-08-2008, 06:07 PM   #2
the Musigician
DangerMouse's Avatar
on the thermostat, is there a switch for auto/on? turn it to auto if so.
DM
Old 11-08-2008, 06:15 PM   #3
x47
Fan switch on thermostat is turned to "AUTO"
Same result if thermostat is turned off or disconnected - fan still runs.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 11:36 PM
carrier furnace issues sbroways HVAC 2 10-15-2007 09:30 PM
Help Please, Furnace won't turn on lh0628 HVAC 8 10-09-2007 04:07 PM
