Carrier Furnace Error Codes - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 07:37 AM   #1
This is my first post, and I'm thrilled to find this site.
I have an 8-year-old Carrier 58TUA12016 furnace. When I turn on the heat, I get the following sequence of events:
1. the blower motor goes on for the correct length of time. But while it's going, the control unit is giving me a 12 code (1 short, 2 long).
2. the blower stops and the inducer motor comes on.
3. The next step should be the little strip of metal glowing orange, and the gas flow starting. But when the little click happens, the glow doesn't come, the gas doesn't start, and I get a 32 code.
Any ideas? Anybody fixed a similar problem?
Scott
spcook is offline   Reply With Quote
Old 10-13-2009, 05:59 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
There is a legend on the back of the furnace door or in the owners manual telling you what a code 32 is. Cannot find that on my chart. Post it here.
Old 10-14-2009, 07:42 AM   #3
Yuri - Thanks for responding!
Actually, that's one of my problems - I can't find the manual, and the codes aren't listed on the inside of the door.
I'm trying to track down a pdf of the manual. I'll respond when I get it.
Thanks!
Old 10-14-2009, 08:48 AM   #4
Rewards Points: 6,652
http://www.residential.carrier.com/support/index.shtml
Do a search with '58TUA' as the model @ http://www.residential.carrier.com/a...s/form.jsp?b=c I was able to find the books with little search needed from Carrier's website.
Old 10-14-2009, 09:44 AM   #5
Thanks, gregzoll!
The manual still doesn't have the codes, but I found this description of Code 32 elsewhere on the board.
- Improper vent sizing (don't think so, this has not changed)
- Low inducer motor voltage 115 V (I'll check but I don't think so)
- Defective Inducer Motor (Nope - it always comes on)
- Excessive wind (nope)
- Inadequate combustion air supply (ust replaced filter and there are no other obstructions)
- Disconnected or obstructed pressure tubing (Is this the little bit of black rubber tube below the gas valve? I'll check it)
- Defective pressure switch (I think this or the pressure tubing may be the problem)
- Restricted vent (Nope)
I'm guessing the pressure switch or the pressure tubing. Is there an existing thread on how to check or repair this?
Thanks for your help!
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 05:16 PM
Carrier 58MCA Furnace No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 07:32 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
