Carrier Furnace Error Code 34 Comfort 80 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 08:43 PM   #1
I have read as much as I can on here and other places about these codes. The furnace igniter glows 2 out of the 3 burners start, but the 3rd doesn't. This doesn't not happen every time. If we turn the switch on the side on and off (after lock out) it starts and attempts again. The 3rd will light after a few attempts and rarely locks out. But why is this happening? It seems all other things are functioning properly. I have read to clean the igniter with sand paper or steel wool and/or clean the burner out. Should this fix it?
bamsgl is offline   Reply With Quote
Old 12-13-2011, 08:47 PM   #2
Rewards Points: 460
Not the ignitor. Clean the flame sensor.
diyorpay is offline   Reply With Quote
Old 12-13-2011, 08:58 PM   #3
An old Tradesmen
Rewards Points: 6,074
Burners are dirty. The cross overs aren't letting enough gas go through them, thats why the third burner doesn't light. Need pulled and cleaned.
The Following User Says Thank You to beenthere For This Useful Post:
bamsgl (12-13-2011)
Old 12-13-2011, 09:50 PM   #4
We will try this as soon as the boys go to bed.
Old 12-30-2011, 05:48 AM   #5
OP, hope you had luck with your furnace issue. Can anybody advise how to find the flame sensor on the Carrier Comfort 80? I've never worked on a furnace before. Thanks in advance.
acr89 is offline   Reply With Quote
Old 12-30-2011, 10:08 AM   #6
Generally speaking, flame sensors are locate in front of the burner rack, opposite of the ignitor.
harleyrider is offline   Reply With Quote
Carrier Furnace code 33 @ startup blower fan sounds like jet Frank Ottawa HVAC 6 04-19-2011 08:12 AM
Carrier Furnace: Code 42 gonzochris HVAC 3 03-06-2011 01:32 PM
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 09:07 PM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 08:45 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
