Carrier Furnace "diode Jumpstart" Instructions? After Filter Shutdown - HVAC - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 08:11 PM   #1
Carrier furnace "diode jumpstart" instructions? after filter shutdown
About a year ago I got wonderful help here "resetting" my Carrier 58RAV furnace. The thread had digital photos and a long sequence of instructions that showed how to do a reset to (I think) the diode/flame switch/or ?? There was a jumper cable involved.
Looks like I did it again (waited to long to replace the filters) and I'm desperately trying to find them again - Please if you have any idea how to do this let me know -
"Freezing in Seattle"
Thank you in advance for your help.
lf-carrier58RAV is offline   Reply With Quote
Old 03-05-2009, 08:42 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
What was your user name a year ago?
Old 03-05-2009, 08:51 PM   #3
I was just following some other persons thread...
I was not registered (I don't think).
Old 03-05-2009, 09:14 PM   #4
Rewards Points: 560
Let's see are you getting flash code on the control board?
If so what?
Turn off power to the furnace and then turn it back on and turn up the stat and see if it works?
It may have gone into a lockout
Old 03-05-2009, 09:26 PM   #5
getting a 34 code
It starts up with a 12 and then after trying to light the burner it goes to 34.
Old 03-05-2009, 09:31 PM   #6
Rewards Points: 560
Does the furnace actually lite the burners?
If so for how long?
On the door panels there should be a code fault chart please post
Old 03-05-2009, 10:16 PM   #7
photo of status codes Carrier 58RAV...(and the flame never lights)
Old 03-06-2009, 01:51 AM   #8
HvacWiz's Avatar
Rewards Points: 252
you either have a bad ignitor or the flame sensor needs cleaned.
HvacWiz is offline   Reply With Quote
Old 03-06-2009, 07:58 AM   #9
I already cleaned the flame sensor with fine steel wool as I learned from this site, so I guess I will buy a new ignitor and hope it works.
Thank you and the others here at DIY for your advice and assistance - special thanks to Plumber101 for responding so quickly last night. I'll be back with the 'rest of the story' when I get it fired up!
- Freezing in Seattle
Old 03-06-2009, 08:30 AM   #10
"hot surface ignitor"
does anyone know what a "hot surface ignitor" is? (circled in red in photo) I did the self-test and everything seemd to work (motors, etc.) but I'm not sure where the "hot surface ignitor" is located.
Is it the "ignitor" piece? I wish Carrier would use the same terminology throughout. Oh well.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Zoning With Carrier Infinity Furnace ddartmouth HVAC 1 01-05-2009 11:55 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace minus filter dsal HVAC 16 02-24-2008 12:26 PM
