Carrier Furnace - Code 42 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 01:09 AM   #1
Carrier furnace - Code 42
I am getting an inducer motor failed to reach speed failure. The inducer motor never starts. There is 120v at the plug. The motor assembly has been replaced. No water problems. Ran component test and only 42 code comes up. Ran in emergency heat mode and main blower ran at high speed, nothing at the inducer. Any suggestions on the next step???
deanray is offline   Reply With Quote
Old 10-04-2008, 01:53 AM   #2
HvacWiz's Avatar
Rewards Points: 252
120 volts at the motor plug ? If so you need a new motor, if this is a varible speed motor and you say it allready has been replaced you might be looking at a new circuit board. whats the model # ?
HvacWiz is offline   Reply With Quote
Old 10-04-2008, 09:14 AM   #3
Carrier Model 58MVP
This is a variable speed from GE Motors, ECM ,4000 rpm. There are 6 leads to motor assembly.120v w/ground and three additional going to the control board. Am I right in assuming they are some sort of speed signal originating in the CPU?
Carrier furnace help code 13 mudtruck HVAC 10 11-23-2013 02:24 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Carrier Furnace LED Code 34 and 14 sherjack HVAC 20 11-01-2009 08:45 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 12:00 AM
