Carrier Furnace Code 12 - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 08:01 PM   #1
Carrier Furnace code 12
I have a Carrier Furnace, I replaced about a month ago the flame rod, I checked it all is good there...blowere goes on, it seems no gas getting to the furnace, anything I can do to get this working without calling a contractor???
WhataboutBob is offline   Reply With Quote
Old 03-16-2011, 08:14 PM   #2
What sites code 12 mean please enter description with code then I can help
heatycooly is offline   Reply With Quote
Old 03-16-2011, 08:16 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
that is a code of power was turned off and then on during a call for heat. Let the blower run 90 seconds and then post either a new code or what happens after the 90 seconds. OR you read the code wrong and it is 21.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-17-2011, 09:19 PM   #4
HVAC Tech/ Browns Fan
It a limit open. Check filter and ac coil. If both or one is dirty can make limit to trip. I also check if you have vents closed.
Tator1076 is offline   Reply With Quote
Carrier furnace help code 13 mudtruck HVAC 10 11-23-2013 03:24 PM
Carrier Infinity 58MVb Code 13 Earl B HVAC 4 10-19-2011 09:44 AM
Carrier Error code 34 with more totallylost HVAC 13 12-21-2010 06:24 PM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 08:19 PM
Carrier Furnace LED Code 34 and 14 sherjack HVAC 20 11-01-2009 09:45 AM
