Carrier Furnace And Aprilaire Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 09:06 PM   #1
Exclamation
Carrier Furnace and Aprilaire not working
I hope there is an easy fix - I purchased a new Carrier Weathermaker 9200 about 7-years ago. Not getting much humidity so I went to change the water pad in the Aprilaire 700 humidifier. The pad is scale free, the fan is spotless - both look like they have never been used - I have seen the humidifiers after a couple of years and know they get very thick buildup. I tried to do the test mode on the humidifier with the furnace fan running and nothing happened. I checked the wireing and nothing is obvious. I don't think this thing has run for years. any advice?
meanj22 is offline   Reply With Quote
Old 01-03-2012, 09:12 PM   #2
turn the humidistat to the test mode, turn temperature up on furnace at thermostat......make sure the water is on to the humidifier. wait a few minutes and you should have water flow and the fan should be running,if not you will need a volt meter to start trouble shooting.
harleyrider is offline   Reply With Quote
Old 01-03-2012, 09:22 PM   #3
Thank you
Thanks Harley - that did get some water running, but still no fan turning on in the unit - however, it is now giving some water, so that is good.
Old 01-03-2012, 09:29 PM   #4
can you follow the large black wire and make sure the unit is plugged in?
Tags
aprilaire , carrier
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
Aprilaire 700A on Goodman Furnace? kcrossley2 HVAC 50 02-18-2012 04:41 PM
Armstrong Furnace and Aprilaire humidifier wont shut off! HELP! scott0949 HVAC 8 12-09-2010 06:30 PM
Carrier MPV Furnace & Aprilaire humidifier mikeramos HVAC 4 11-21-2008 05:04 PM
Aprilaire 700 to Carrier product # FK4BNF003000AAA mag-md HVAC 10 12-17-2006 07:49 PM
