Carrier Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 03:14 PM   #1
Carrier furnace
I am working on a Carrier furnace. The code blinks 13. I changed out the parts pressure switch, reset switchs, main board. But it still will not get the HSI to click on. The vent fan goes thru it's 90 seconds and pauses and the blower fan will come on. But there is no signal to the HSI.
What else can it be.
MikeLE is offline   Reply With Quote
Old 11-05-2010, 03:15 PM   #2
I do maintenance and do work on furnaces but cannot figure this one.
Old 11-05-2010, 03:46 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Which model # is it? Mid or high efficiency? There should be a spill switch on the box where the smokepipe/venting attaches on a mid with a manual reset button located on the right side underneath it. On a high efficiency they should be on the sides of the burner box. Look carefully for them. Code 13 is open limit.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Carrier 58MCA Furnace No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 07:32 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
