Old 01-06-2013, 06:02 PM   #1
carrier furnace
my furnace will run until the room is to the thermostat set temp. It then goes to the blower only. The led flashes 1 short 1 long then 3 short, it is 8 years old
wpm paul is offline   Reply With Quote
Old 01-06-2013, 06:36 PM   #2
carrier furnace
hi on the panel some place on the furnace there should be a label explaining the codes ,, look see what code it is and let us know which saftey its going off on,,model number to will help
hvac dude is offline   Reply With Quote
Old 01-06-2013, 09:18 PM   #3
HVAC Tech/ Browns Fan
carrier furnace
It 13 code. Limit or roll out switch. Check filter
Tator1076 is offline   Reply With Quote
Old 01-06-2013, 09:46 PM   #4
carrier furnace
the filter is clean
Old 01-06-2013, 09:47 PM   #5
carrier furnace
did you check the codes on the panel ?? thats where you should start
Old 01-06-2013, 10:07 PM   #6
carrier furnace
model # 58msa
Old 01-06-2013, 10:09 PM   #7
carrier furnace
wpm please look on the panel for codes it will sure speed up the process ty
Old 01-06-2013, 10:17 PM   #8
carrier furnace
Check the description of the codes on the panel. It will tell you what's going on.
I don't have the codes memorized.
kirwinjd is offline   Reply With Quote
Old 01-06-2013, 11:07 PM   #9
how
carrier furnace
I believe a code 13 means that a limit or roll out switch has be activated for more than 3 minutes.
Either the furnace has been overheating/ the flame has been rolling out the front of the heat exchanger/ the limit or rollout switch is faulty.
This is code that may be indicating a serious monoxide condition.
Do you have a/c? (dirty coil?) Are all the heating and return vents open or uncovered? Do you have dirty air filters in the heating outlets?
A electrical meter will tell you if either the main limit or the roll out switches have tripped.
A temp rise test will tell you if the furnace is actualy overheating.
how is offline   Reply With Quote
Carrier furnace problem. Pilot lights, no burner Donut HVAC 1 02-09-2011 09:07 PM
What are the carrier furnace codes? porang HVAC 1 01-24-2011 08:45 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 06:16 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 10:48 AM
