-   -   Carrier FC4BNF036 Air Handler (3 ton) sick (http://www.diychatroom.com/f17/carrier-fc4bnf036-air-handler-3-ton-sick-10219/)
kaineb 07-28-2007 12:33 AM
Hello all, No0b With a quick question. Appreciate any help you are willing to give! So, Beginning of hot season it would take quite a while but the unit would eventually cool the house down from 80 during the day to 73 at night. 90 - 95 degree outside temp. All of a sudden one night it stopped cooling so well. I noticed that the cooler it is out the better the unit feels. Some times it feels mildly cool and other times ambient. I took apart the air handler to do a cleaning but everything was spotless. There are no strange noises, the unit had worked ok, etc. I have a 1500 sqft house, 1 zone, 3 ton unit. I noticed that the coil was rusted on the sides. Unit is 8 years old. I don't have the money for a pro right now to replace large items. Any suggestions? FYI the outside unit is 1 year old and clean. Everything kicks on when it should as well.
Farmer 07-28-2007 01:01 AM
If you can't afford a serviceman and don't have gauges and thermometers to get your superheat and subcooling and you don't have a cylinder of refrigerant, it may be a long hot summer for you.
At one year old, your condenser should still be in warranty.
kaineb 07-28-2007 10:11 AM
well the unit in question is actually the coil in the air handler in the attic, about 8 years old. The new unit is the one that is outside. Going to have a local guy come see if it is low in freon. We will see. From the looks of it since it is all rusty i suppose it needs to be replaced at some time.
But thank you for the comments. What is superheat?
Malcolm 07-28-2007 11:14 AM
The units work as one. If your condensing unit was installed during the winter, it would have been hard to charge correctly. Moreover, there could be a leak on one of the outside connections. If it is still under warranty for the condenser, I would call the company that installed it to look at it. Don't mention anything about the coil as you do not know if it is leaking.
