Carrier Elect. Furnace/ac,fan Runs No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 09:59 AM   #1
carrier elect. furnace/ac,fan runs no heat
are there heating elements that i can replace in my furnace? SYMPTOMS;fan runs on "on" but shuts off after a few moments on "auto".filter has been changed. no burnt element smell in the house (if that matters). no heat comes out of vents!
gtatertot is offline   Reply With Quote
Old 01-21-2009, 12:42 PM   #2
JohnH1's Avatar
1st I just want to make sure you have a all electric furnace and not gas or other. Next in auto position and a call for heat you say the blower starts on it own and then turns back off wile still calling for heat is this correct?
JohnH1 is offline   Reply With Quote
Old 01-21-2009, 08:18 PM   #3
Dr Heat's Avatar
Some electric furnaces use a different breaker for the fan (110 v or 220v) then any number of breakers for the elements these are generally but not always 220 v
It could be as simple as a tripped breaker.
If not answer John's questions
Please do not go poking around electric furnaces are very safe till you open the door, then they are arguably the most dangerous.
Dr Heat is offline   Reply With Quote
Old 01-21-2009, 11:29 PM   #4
hope thats not why he hasnt replied
kennzz05 is offline   Reply With Quote
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 01:42 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 12:00 AM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
